Class 4 (4th Engineer) SC&S 📅 Dec 2022
Sketch a double bottom tank for storage of fuel oil tank and ballast water, showing the position of all internal fittings. On an internal inspection, what defects will you look for? (16)
### **Part 1: Double Bottom Tank Sketch and Internal Fittings**
A double bottom tank designed for the carriage of either fuel oil or ballast water is a critical structural and operational component of a vessel. Its design incorporates robust framing and various fittings to ensure structural integrity, safe handling of liquids, and ease of inspection and maintenance. A sketch would show a transverse cross-section.
**Key Structural Components and Fittings:**
* **Tank Top Plating:** Forms the top boundary of the tank and the floor of the cargo hold or engine room above.
