Class 4 (4th Engineer) MEKG 📅 May 2024
Sketch and describe a contra flow type heat exchanger for the auxiliary engine applications (16)
### **1. Principle of Operation: Contra-Flow Heat Exchanger (4 Marks)**
A contra-flow, or counter-flow, heat exchanger is a device designed to transfer thermal energy from a hot fluid to a colder fluid, where the two fluids flow in parallel but in opposite directions. This arrangement is the most efficient of all flow types for heat exchange.
* **Fundamental Concept**: The primary objective in an auxiliary engine application (e.g., cooling jacket water or lube oil) is to maximize heat transfer with the smallest possible surface area and the lowest flow rate of the cooling medium.
* **Thermodynamic Efficiency**: In a contra-flow arrangement, the cold fluid enters where the hot fluid exits, and exits where the hot fluid enters. This maintains a more uniform Temperature Difference (ΔT) across the entire length of the heat exchanger. This results in a higher Log Mean Temperature Difference (LMTD) compared to parallel flow, leading to a higher rate of heat transfer for a given surface area.
