Class 4 (4th Engineer) MEKM 📅 Oct 2022
Sketch and describe a cylinder head for a large diesel engine and show the provision made for cooling. Explain how the water spaces are examined and state the usual causes of cracking. (16)
### **1. Description and Construction of a Cylinder Head**
The cylinder head, also known as the cylinder cover, is a critical component of a large two-stroke diesel engine. It serves multiple essential functions:
* **Sealing the Combustion Space**: It forms the upper boundary of the combustion chamber, containing the high pressures and temperatures generated during combustion.
* **Housing Engine Components**: It provides bores and passages for mounting essential valves such as the central exhaust valve, fuel injectors, air starting valve, safety valve, and an indicator cock.
