Class 4 (4th Engineer) MEKM 📅 Mar 2025
Sketch and describe a device employed for continuous monitoring of the viscosity of heavy fuel oil being supplied to a main engine. (16)
Heavy Fuel Oil (HFO) viscosity is a critical parameter for optimal combustion and efficient operation of marine diesel engines. If the viscosity at the engine inlet is too high, atomization will be poor, leading to incomplete combustion, carbon deposits, increased exhaust emissions, and excessive wear on fuel injection equipment. Conversely, if the viscosity is too low, the lubricating properties of the fuel diminish, causing wear in fuel pumps and injectors, potential for fuel leakage, and an increased risk of ignition delay (knock). Therefore, continuous monitoring and automatic control of HFO viscosity are paramount. A common and highly effective device employed for this purpose is the **Vibrating Rod Viscometer (also known as a Vibrating Tine or Spool Viscometer)**, which provides real-time viscosity measurements directly within the fuel line.
### 1. Principle of Operation
The vibrating rod viscometer operates on the principle of measuring the damping effect a fluid has on a resonating element. The device consists of a probe, typically a rod, tube, or spool, which is made to vibrate at its natural resonant frequency or at a constant amplitude.
* **Resonance and Damping**: When immersed in the HFO, the fluid's viscosity exerts a damping force on the vibrating element. The more viscous the fluid, the greater the damping effect.
