Class 4 (4th Engineer) MEKM 📅 Nov 2025
Sketch and describe the operation of a crankcase oil mist detector. What operational maintenance does this instrument require for efficient performance. (16)
### Introduction and Principle of Operation
A crankcase oil mist detector (OMD) is a critical safety device installed on large marine diesel engines. Its primary function is to provide an early warning of an abnormal condition within the crankcase, such as an overheating bearing, piston blow-by, or scavenger fire. It achieves this by continuously monitoring the density of oil mist in the crankcase atmosphere. An explosive condition exists when the oil mist concentration is between its Lower Explosive Limit (LEL) and Upper Explosive Limit (UEL). The OMD is designed to trigger an alarm at a concentration well below the LEL (typically around 2.5% of LEL), allowing for timely intervention to prevent a potential crankcase explosion.
The device operates on the principle of light obscuration or light scattering. It compares the optical clarity of a sample drawn from the crankcase against a reference sample of clean air. A deviation beyond a preset limit indicates an increased concentration of oil mist, triggering an alarm.
### Construction and Operation
