State some built in measures by which the steering gear mechanism can be kept operational, in the event of breakages, pipe failures, motor burn out etc. (16)
The steering gear mechanism is a critical piece of equipment for the safe navigation and operation of a vessel. Consequently, international regulations, primarily the International Convention for the Safety of Life at Sea (SOLAS), mandate significant redundancy and built-in measures to ensure its operational continuity even in the event of component failures such as pipe failures, motor burn-out, or other breakages. As a Senior MEO Class 1 Examiner, a comprehensive understanding of these measures is essential.
### 1. Regulatory Framework (SOLAS Chapter II-1, Regulation 29)
These measures are largely driven by SOLAS requirements, which stipulate:
* **Main Steering Gear Performance**: Must be capable of putting the rudder from 35 degrees on one side to 35 degrees on the other side when the ship is at its deepest sea-going draught and proceeding ahead at maximum service speed, within 28 seconds.
