Class 4 (4th Engineer) SSEP 📅 Dec 2024
State why the following equipments require shut down during a major fire which has necessitated the evacuation of the machinery spaces:
(a) Settling and service tank valves. (4)
(b) Fuel transfer and supply pumps. (4)
(c) Mechanical and natural ventilation. (4)
(d) State how the fire is brought under control using the facilities available outside the machinery spaces. (8)
### (a) Settling and Service Tank Valves (4 Marks)
Shutting down settling and service tank valves, typically through remote-operated Quick Closing Valves (QCVs), is a critical step in isolating a machinery space fire for the following reasons:
1. **Elimination of Fuel Supply**: This is the primary reason. It directly attacks the 'Fuel' side of the fire tetrahedron. Service and settling tanks hold a significant volume of flammable fuel. Closing these valves prevents this fuel from feeding the fire, which would otherwise lead to a catastrophic escalation.
2. **Prevention of Gravity Feed**: Service tanks are located at a high level within the machinery spaces to provide a positive head to the supply pumps. If the valves were left open, fuel could continue to flow into the engine room under gravity even with all pumps stopped, continuously supplying the fire source.
