Class 4 (4th Engineer) MEP 📅 Oct 2023
State with reasons which one of the following would most help to correct a pronounced discoloration of the M/E lubricating oil: (16)
(a) "Make up" from reserve tanks
(b) Increase purifier throughput
(c) Increase frequency of filter pack cleaning
(d) Overhaul piston rod stuffing boxes
(e) Check tank top integrity of sump tank
### Analysis of Options for Correcting Lubricating Oil Discoloration
The most effective action to correct a pronounced discoloration of the Main Engine lubricating oil is **(d) Overhaul piston rod stuffing boxes**. Discoloration is a symptom of contamination, and a full-marks answer requires identifying and rectifying the root cause, not merely treating the symptom.
Here is a detailed analysis of each option:
#### (d) Overhaul piston rod stuffing boxes (Correct Answer)
