Class 4 (4th Engineer) MEKG 📅 May 2024
The by-products of oxidation, as a result of water contamination of hydraulic oil are generally: (16)
(a) Removed by cellulose type filters
(b) Gums, varnishes, and acids
(c) Always neutralized by oil additives
(d) Harmless and have no effect on system components
Briefly justify your answer.
### Correct Answer
### Justification
This answer receives full marks for correctly identifying the by-products and providing a detailed, surveyor-grade justification explaining the chemical process and its detrimental effects on hydraulic systems, while also systematically disproving the incorrect options based on sound engineering principles.
