Class 4 (4th Engineer) MEKG 📅 Oct 2024
The by-products of oxidation, as a result of water contamination of hydraulic oil, are generally (16)
(a) Removed by cellulose type filters
(b) Gums, varnishes, and acids
(c) Always neutralized by oil additives
(d) Harmless and have no effect on system components
Briefly justify vour answer.
### Correct Answer
### Justification
This answer receives full marks for correctly identifying the by-products and providing a detailed, surveyor-grade justification explaining the chemical process and its detrimental effects on hydraulic systems, while also systematically disproving the incorrect options based on sound engineering principles.
