Class 4 (4th Engineer) MEP 📅 Oct 2023
The exhaust temperatures of an auxiliary diesel are found to be excessive and uneven at normal load, with dark exhaust at the funnel.
Describe EACH of the following:
(a) An investigation of the situation (5)
(b) The procedure to remedy the immediate problems (6)
(c) Any further action that might be necessary (5)
### (a) Investigation of the Situation (5 Marks)
A systematic investigation must be conducted to ascertain the root cause of the observed symptoms: excessive and uneven exhaust temperatures, accompanied by dark exhaust smoke. The approach should be logical, progressing from external checks to internal component verification.
1. **Initial Data Collection & Symptom Analysis:**
* Immediately record all relevant engine parameters at the current load: individual exhaust temperatures, scavenge air pressure, turbocharger RPM, engine load (kW), individual fuel rack positions, LT cooling water temperatures, and ambient conditions.
