Class 4 (4th Engineer) SC&S 📅 Dec 2025
The ½ ordinates of a waterplane 120 m long are as follows:
Section
AP
½
1
1½
2
3
4
5
6
7
8
8½
9
9½
FP
½ ord
1.2
3.5
5.3
6.8
8.0
8.3
8.5
8.5
8.5
8.4
8.2
7.9
6.2
3.5
0
Calculate: (16)
(a) waterplane area
(b) distance of centroid from midships.
### **Objective**
To calculate the waterplane area (Awp) and the longitudinal position of its centroid (LCF) from midships using the provided half-ordinates for a ship of 120m length.
### **Principle & Method**
This problem will be solved using Simpson's First Rule for numerical integration. The ordinates are not equally spaced throughout the length; there are half-spaced ordinates at the ends. Therefore, the waterplane will be divided into three sections, and Simpson's rule will be applied to each section individually. The results will then be summed.
