Class 4 (4th Engineer) SSEP 📅 Feb 2024
Using a simple sketch, describe the fire main of a ship with which you are familiar. Include in your answer:
(a) The number and type of pumps (5)
(b) Material of the piping (5)
(c) Significance of the drain valve (5)
(d) Location of the international shore coupling (5)
A ship's fire main is a high-pressure piping system that runs the length of the vessel, typically on the main deck, with branches to various decks and spaces. Its primary function is to deliver seawater to fire hydrants, hose reels, sprinkler systems, and other firefighting appliances at a pressure and flow rate sufficient for combating fires onboard.
### (a) The Number and Type of Pumps
As per SOLAS Chapter II-2, Regulation 10.2, the number and arrangement of fire pumps are dictated by the ship's type and tonnage. For a typical cargo ship of over 1000 GRT, the following are required:
* **Number of Pumps:** A minimum of **two** independently driven power pumps are mandatory. In practice, most ships have at least three to ensure redundancy.
