Class 4 (4th Engineer) MEKM 📅 Aug 2022
When a medium-speed diesel engine is used for propulsion purposes, a coupling is required between engine and reverse /reduction gear-
(a) Sketch a hydraulic coupling for the above stated purposes (6)
(b) Describe how it operates. (6)
(C) State what advantages such couplings have over their friction and magnetic alternatives. (4)
### (a) Sketch of a Hydraulic Coupling
A diagram of a hydraulic coupling (also known as a fluid coupling) should clearly illustrate the following components:
* **Primary Wheel (Impeller/Pump):** This is connected to the input shaft, which is driven by the engine. It is a vaned rotor that acts as a centrifugal pump.
* **Secondary Wheel (Runner/Turbine):** This is connected to the output shaft, which drives the reverse/reduction gearbox. It is a vaned rotor that acts as a turbine.
