Class 4 (4th Engineer) MET 📅 Nov 2024
With reference to a three phase shipboard electrical distribution system;
(a) Enumerate the advantages of an insulated neutral system: (4)
(b) Enumerate the disadvantages of an insulated neutral system; (4)
(c) Compare the use of an insulated neutral system as opposed to the use of an Earthed neutral system with regard to the risk of electric shock from either system. (8)
### (a) Advantages of an Insulated Neutral System
An insulated neutral system, where the generator's neutral point is not intentionally connected to the ship's hull (earth), offers several key advantages critical for maritime operations:
1. **Continuity of Supply:** This is the most significant advantage. In the event of a single earth fault on one phase, a large fault current does not flow. The system is not required to trip immediately. This ensures that essential services such as steering gear, main engine support systems, and navigation equipment remain operational, preventing a potentially catastrophic loss of control.
2. **Enhanced Safety on First Fault:** As stated in the provided context, an insulated neutral system "does not pose any danger to human life even if there is a single earth fault because the whole ship will be at same potential". When a single phase faults to the hull, the hull potential rises to that of the faulty phase. Since there is no low-impedance return path to the neutral, a person touching the faulty equipment and the hull simultaneously will have no significant potential difference across their body, minimizing the risk of electric shock.
