Class 4 (4th Engineer) SSEP 📅 Mar 2025
With reference to an emergency source of electrical power in cargo ships:
(a) Describe a typical power source. (10)
(b) Give a typical list of essential services, which must be supplied simultaneously. (5)
(c) Explain how the emergency installation can be periodically tested. (5)
With reference to an emergency source of electrical power in cargo ships, a comprehensive description and testing procedure is provided as per Surveyor-Grade standards.
**(a) Describe a typical power source.**
The typical emergency source of electrical power in cargo ships is an independent **Emergency Diesel Generator Set**. This installation is crucial for maintaining essential services in the event of a main power failure (blackout) and is designed to operate reliably under emergency conditions. Its design and installation are strictly governed by SOLAS Chapter II-1, Part D, Regulations 42 and 43.
* **Location and Protection**: The emergency generator and its associated components (fuel tank, starting batteries, switchboard) must be located outside the main machinery space, above the uppermost continuous deck, and in a position that ensures maximum availability and protection from fire, flooding, and damage. It is often housed in a dedicated emergency generator room, accessible from the open deck, and arranged to ensure its operational capability in the event of damage to the main machinery or main electrical supply.
