Class 4 (4th Engineer) MEKM 📅 Apr 2023
With reference to auxiliary engine fuel pumps:
(a) Explain how a fuel pump may be checked for accuracy of injection timing; (6)
(b) Describe how fuel pump timing may be adjusted after overhaul; (5)
(c) Explain the circumstances in which it is considered necessary to replace a fuel pump. (5)
### (a) Checking the Accuracy of Fuel Pump Injection Timing (6 Marks)
**1. Safety and Preparatory Procedures:**
Before checking the timing, the following essential safety precautions must be taken:
* Inform the Bridge and obtain permission for engine immobilization.
