Class 4 (4th Engineer) MEKM 📅 Nov 2022
With reference to auxiliary engine fuel pumps:
(a) Explain how a fuel pump may be checked for accuracy of injection timing (6)
(b) Describe how fuel pump timing may be adjusted after overhaul (5)
(c) Explain the circumstances in which it is considered necessary to replace a fuel pump. (5)
### (a) Checking the Accuracy of Fuel Pump Injection Timing (6 Marks)
**1. Safety and Preparatory Procedures:**
Before checking the timing, the following essential safety precautions must be taken:
* Inform the Bridge and obtain permission for engine immobilization.
