Class 4 (4th Engineer) MEP 📅 Jan 2026
With reference to exhaust valves of an auxiliary diesel engine
(a) Describe how valves are reconditioned (8)
(b) Explain how valve timing is checked and corrected. (8)
### (a) Reconditioning of Auxiliary Engine Exhaust Valves (8 Marks)
Reconditioning of an exhaust valve is a meticulous process aimed at restoring its geometry and material properties to the manufacturer's original specifications. This is essential to ensure gas-tight sealing, efficient heat transfer, and longevity. The process involves multiple stages of inspection, material build-up, and precision machining.
**Surveyor-Grade Procedure for Valve Reconditioning:**
1. **Pre-Cleaning and Initial Inspection:**
