Class 4 (4th Engineer) MEP 📅 Sep 2022
With reference to hydraulic deck machinery:
(a) State the sources for contamination of the system (6)
(b) Describe possible effects due to contamination (5)
(c) Explain how ships staff can monitor the oil. (5)
### (a) Sources for Contamination of the Hydraulic System
Contamination is the primary cause of malfunction and failure in hydraulic systems. The sources are varied and can be categorized as either built-in, internally generated, or externally introduced.
1. **Water Ingress:** This is a significant contaminant in the marine environment.
* **Direct Ingress:** Entry through worn or damaged ram seals on deck actuators (e.g., crane cylinders, mooring winch brakes), pump shaft seals, and tank breather vents, especially during heavy weather or deck washing.
