Class 4 (4th Engineer) MEKG 📅 Oct 2022
With reference to Main air compressor reservoirs:
(a) Sketch the manner in which mountains are attached to the shell. (6)
(b) Explain why regular internal inspection is advisable. (5)
(c) Differentiate between the specific functions of relief valve and fusible plugs (5)
### (a) Attachment of Mountings to Air Receiver Shell
Mountings on a high-pressure vessel like a main air receiver are not attached directly to the shell plate. Openings for connections create areas of high stress concentration, which could lead to fatigue cracking and catastrophic failure under pressure cycling. To prevent this, the shell is reinforced around the opening.
**Method of Attachment:**
1. **Reinforcing Pad (Compensating Ring):** A thick, shaped steel plate, known as a reinforcing pad or compensating ring, is welded onto the external surface of the receiver shell where the mounting is to be located. The cross-sectional area of this pad compensates for the material removed from the shell for the opening.
