Class 4 (4th Engineer) MEKG 📅 Aug 2024
With reference to main air reservoirs:
(a) Explain with line sketch the manner in which mountings are attached to the shell. (6)
(b) Explain why regular internal inspection is advisable (4)
(c) What are the areas that need particular attention during the inspection and survey of a main air resoroir. (6)
### (a) Attachment of Mountings to Air Reservoir Shell
**1. Principle of Reinforcement:**
An air reservoir is an unfired pressure vessel, and any opening cut into its shell for mountings (e.g., valves, pressure gauges, access doors) creates a point of high stress concentration. The material removed can no longer carry the stress, leading to a localized increase in stress in the material immediately surrounding the hole. As cited in the provided context, to mitigate this and maintain the vessel's structural integrity, **compensation rings or reinforcing pads** are fitted.
**2. Method of Attachment:**
