Class 4 (4th Engineer) MEKG 📅 Aug 2022
With reference to main refrigeration plants give reason for each of the following operational irregularities and state how these are dealt with:
(a) Rapid loss of lubricating oil from the crankcase of a "Vee" block compressor (4)
(b) Steady "fail off" in refrigeration effect over a comparatively short period of time (4)
(c) Excessive "icing up" at compressor suction (4)
(d) Short cycling (4)
### (a) Rapid Loss of Lubricating Oil from Compressor Crankcase
**Reason:**
Rapid loss of lubricating oil from a V-block compressor crankcase is primarily due to excessive oil carryover with the refrigerant gas into the system. The primary causes for this are:
1. **Mechanical Faults:**
