Class 4 (4th Engineer) MET 📅 Jul 2023
With reference to the protection of electric motors explain EACH of the following in relation to Fuse back up protection:
(a) How a motor fitted with fuse back up protection may exceed its rated temperature without being tripped by the primary protection (8)
(b) The value of current rating at which the over current relay should be set. (8)
### (a) How a motor fitted with fuse back up protection may exceed its rated temperature without being tripped by the primary protection
**1. Clarification of Protection Roles:**
In a standard motor protection scheme, often referred to as "Fuse Back-up Protection," the roles are distinct and hierarchical:
* **Primary Protection (for Overload):** This is the **Thermal Overload Relay**. Its function is to protect the motor from sustained overcurrents that are slightly above the Full Load Current (FLC). These conditions cause a gradual rise in winding temperature, leading to insulation breakdown. The relay has an inverse-time characteristic, meaning it trips faster as the overload current increases, designed to mimic the motor's thermal heating curve.
