Class 4 (4th Engineer) MEP 📅 Oct 2024
With regard to keeping the gas side of boilers in good condition discuss EACH of the following:
(a) The mechanism of combustion, stating the factors which are important for good combustion (6)
(b) Oil fuel treatments (5)
(c) Soot removal equipment. (5)
### (a) The Mechanism of Combustion and Factors for Good Combustion
#### Mechanism of Combustion
Combustion in a boiler furnace is a rapid, high-temperature exothermic chemical reaction between a fuel (hydrocarbons) and an oxidant (oxygen from the air) to produce thermal energy. The process for liquid fuel oil occurs in several sequential and overlapping stages:
1. **Atomization**: The fuel oil, delivered at the correct viscosity and pressure, is forced through a burner's atomizer. This breaks the liquid fuel into a fine spray of millions of microscopic droplets, vastly increasing the surface area available for heating and reaction.
