Class 4 (4th Engineer) SC&S 📅 May 2024
With regards to the metacentric height, which of the following statements is true? (16)
(a) It is used to indicate the quality of initial stability.
(b) It is located below the center of buoyancy.
(c) It is measured vertically above the center of buoyancy.
(d) Its determination is the objective of the inclining experiment.
Brefly justify your answer.
The correct statement is **(a) It is used to indicate the quality of initial stability.**
### Justification of the Correct Answer
This statement is fundamentally correct. The Metacentric Height (GM) is the primary quantitative measure of a vessel's initial stability, which is its tendency to return to the upright position after being heeled by a small external force (typically for angles up to 10-15 degrees).
