With reference to the protection of electric motors explain EACH of the following:
(a) Fuse back up protection; (6)
(b) How a motor fitted with fuse back up protection may exceed its rated temperature without being tripped by the primary protection; (6)
(c) The value of current rating at which the over current relay should be set. (4)
Electric motors are critical components in marine systems, and their effective protection is paramount to ensure operational reliability, prevent catastrophic failures, and safeguard personnel. Protection systems must be carefully coordinated to address various fault conditions, from sustained overloads to severe short circuits.
### (a) Fuse Back-Up Protection
Fuse back-up protection refers to the use of fuses in series with other primary protective devices, typically motor overload relays or circuit breakers, to provide short-circuit protection for an electric motor circuit. Its primary purpose is to protect the motor, its starter, and the feeder cables from the damaging effects of very high fault currents, such as those caused by a direct short circuit.
* **Purpose**: The main role of fuses in this context is to provide high interrupting capacity and rapid clearance of large fault currents that the primary protective device (e.g., an overload relay or even a standard moulded case circuit breaker) might not be rated to handle or might not clear quickly enough to prevent significant damage. Fuses are inherently current-limiting devices, meaning they can restrict the peak current that flows during a short circuit.
