Class 4 (4th Engineer) SC&S 📅 Jul 2025
With regards to the metacentric height, which of the following statements is true?
(a) It is used to indicate the quality of initial stability.
(b) It is located below the centre of buoyancy
(b) It is measured vertically above the centre of buoyancy
(c) Its determination is the objective of the inclining experiment.
Briefly justify your answer. (16)
The correct statement is: **(a) It is used to indicate the quality of initial stability.**
### Justification for Correct Statement (a)
Initial stability refers to a vessel's tendency to return to its original upright position after being heeled by a small external force (typically for angles up to 10-15 degrees). The Metacentric Height (GM) is the primary quantitative measure of this characteristic.
1. **Definition of Metacentric Height (GM):**
