Class 4 (4th Engineer) MET 📅 Aug 2025
With respect to personnel carrying out inspection and maintenance involving entry to boiler and other confined spaces:
(a) State the precautions needed for the operations of portable electrical tools and lighting, with respect to safety; (10)
(b) outline the routine checks carried out on the equipments. (6)
### (a) Precautions for Portable Electrical Equipment in Confined Spaces (10 Marks)
Safe operation of portable electrical tools and lighting within a confined space, such as a boiler, is governed by a multi-layered safety approach designed to mitigate the primary risks of electric shock, fire, and explosion. The metallic, damp, and enclosed nature of such spaces significantly elevates these risks.
**1. Electrical Shock Prevention (Primary Hazard)**
* **Use of Reduced Voltage (SELV):** The most critical safety measure is the use of a Separated Extra-Low Voltage (SELV) supply. This is achieved by using a portable step-down transformer, typically with a primary voltage of 230V or 110V and a secondary output of **24V AC**.
