Class 4 (4th Engineer) MEKM 📅 Jul 2024
Write short notes on:
(a) Main air starting valves (4)
(b) Exhaust valve rotator (4)
(c) Scavenge relief valve (4)
(d) Function of Labyrinth Seals in turbocharger (4)
### (a) Main Air Starting Valves
**Concept and Purpose:**
Main air starting valves are critical components in large marine diesel engines, enabling the engine to be rotated from a stopped position to a speed sufficient for combustion to commence. They precisely admit high-pressure starting air into the engine cylinders in a timed sequence, converting the stored potential energy of compressed air into kinetic energy to turn the crankshaft.
**Construction:**
