Class 4 (4th Engineer) MEP 📅 Jul 2025
Write short notes on the following:
(a) The need for taking double bottom tank soundings regularly after a grounding incident. (4)
(b) Need to pre-heat main engines prior to continuous running of the engine. (4)
(c) Utility of pressure gauges on either side of high pressure fuel oil filters. (4)
(d) The purpose of opening indicator cocks before blowing through an engine. (4)
### (a) The need for taking double bottom tank soundings regularly after a grounding incident.
The regular sounding of all double bottom tanks following a grounding incident is a critical procedure for damage control, vessel stability, and pollution prevention. This action provides immediate and continuous feedback on the integrity of the vessel's hull.
1. **Immediate Damage Assessment & Hull Integrity:** Grounding can cause breaches in the outer hull plating. Double bottom tanks are the first compartments affected. An increase in sounding levels in a ballast or void tank indicates ingress of seawater, confirming a hull breach. Conversely, a decrease in sounding levels in a fuel or oil tank indicates a leak outwards into the sea.
2. **Vessel Stability Monitoring:** The ingress of water into double bottom tanks introduces a free surface effect, which reduces the vessel's metacentric height (GM) and thus its stability. Regular soundings allow the crew to calculate the rate and quantity of flooding. This data is essential for ongoing stability calculations to assess trim, list, and overall seaworthiness, and to determine if the vessel is in immediate danger of capsizing.
