Class 2 (2nd Engineer) MEKM 📅 Jul 2022
Referring to latest developments in Turbo Charger application in marine diesel engines, write short notes on the following:
(a) Power Turbine Generators.
(b) Hybrid Turbo Chargers.
(c) Electro-assist Turbo chargers.
Latest Developments in Turbocharger Applications in Marine Diesel Engines
A Power Turbine Generator (PTG) is a system that utilizes the energy of exhaust gases from the main engine to drive an auxiliary turbine, which in turn drives a generator to produce electrical power. The turbine is usually connected downstream of the main turbocharger’s turbine. This setup offers several benefits:
Enhances energy recovery by converting otherwise wasted exhaust gas energy into usable electricity.
