Class 1 (Chief Engineer) Engineering Management 📅 Nov 2023
Referring to various alternatives to tin-based antifouling paints discuss the following:
(a) Hull roughness of different types of antifouling paints. (6)
(b) Enhancement of foul release coating by oil incorporation (6)
(c) Personnel and health safety during application of antifouling paints. (4)
### (a) Hull Roughness of Different Types of Antifouling Paints
Hull roughness is a critical factor influencing a vessel's frictional resistance and, consequently, its fuel consumption and emissions. The type of antifouling paint applied has a profound impact on the evolution of hull roughness over the service life of the coating. The main alternatives to tin-based paints are Self-Polishing Copolymers (SPC), Foul Release Coatings (FRC), and Hard/Insoluble Matrix paints.
1. **Self-Polishing Copolymers (SPC)**:
* **Mechanism**: These paints use a binder, typically a copper or zinc acrylate copolymer, that hydrolyzes (reacts with seawater) at a controlled rate. This process constantly exposes a fresh, active layer of biocide while simultaneously smoothing the surface.
