Class 1 (Chief Engineer) Engineering Management 📅 Oct 2021
Regarding Ballast Water Management Convention explain
(a) Ballast Water Exchange Standard
(b) Ballast Water Performance standard
(c) Treatment methods for ballast water
(d) Approval methods for treatment system using active and non-active substances
(e) What are the marine pollution problems related to port development such as ballast water, dredging and spills from ships
### (a) Ballast Water Exchange Standard (Regulation D-1)
The Ballast Water Exchange Standard (Regulation D-1) of the IMO's Ballast Water Management (BWM) Convention is a method to reduce the risk of transferring Harmful Aquatic Organisms and Pathogens (HAOP) by replacing the coastal water taken on in the departure port with open-ocean water. This method is considered less effective than treatment to the D-2 standard but is a recognized compliance option during the Convention's phase-in period.
**Key Requirements:**
1. **Volumetric Efficiency:** Ships must conduct an exchange with an efficiency of at least 95% volumetric exchange of ballast water.
