(a) Show how the power that is transferred across the air gap of the three-phase induction motor is represented. Explain the terms. What portion of this is useful power? (6)
(b) A 440V shunt motor takes an armature current of 30A at 700 rev/min. The armature resistance is 0.7 ohm. If the flux is suddenly reduced 20 per cent, to what value will the armature current rise momentarily? Assuming unchanged resisting torque to motion, what will be the new steady values of speed and armature current? Sketch graphs showing speed, current and speed as functions of time during the transition from initial to final, steady-state conditions. (10)
