Class 2 (2nd Engineer) MEKG 📅 Aug 2023
(a) Sketch a line diagram showing a typical Inert Gas System used for inerting the cargo tanks of oil tankers. labelling the component parts.
(b) Describe the system
(c) State what oxygen content you would expect in the flue gases if good combustion is achieved (16)
### (b) Description of the Inert Gas (IG) System
#### Principle and Purpose
The Inert Gas (IG) System is a critical safety installation on oil tankers, designed to prevent explosions in cargo tanks. The primary principle is to reduce the oxygen content within the tank atmosphere to a level where combustion cannot be initiated or sustained. This is achieved by replacing the air in the tank with an inert gas, which is a gas mixture containing a low concentration of oxygen. SOLAS Chapter II-2, Regulation 4 requires tankers of 20,000 DWT and above (and certain others) to be fitted with a fixed IG system.
The system must be capable of rendering the tank atmosphere non-flammable (inert) and maintaining this condition throughout all cargo operations, including discharge, de-ballasting, and tank cleaning.
