Class 2 (2nd Engineer) MEKG 📅 Nov 2022
(a) Sketch a ship's indirect refrigeration system arranged for cooling containers stowed in stacks in the hold
(b) Describe the refrigeration system sketched in (a)
(c) State the advantages and disadvantages of the system described in (a) compared with containers with their own refrigeration self-contained units.
### (a) Sketch of an Indirect Refrigeration System for Containers
*(A sketch is required to be drawn by the candidate. The sketch should clearly label the components as described below.)*
The diagram should illustrate:
1. **Primary Refrigeration Plant:** Located in the engine room or a dedicated machinery space, showing the Compressor, Condenser (with Sea Water cooling), Receiver, and Evaporator (Brine Cooler).
