Class 2 (2nd Engineer) MEKG 📅 Mar 2023
Sketch an arrangement of propeller shaft and stern in which the tube is filled with oil and
(a) Describe the attention it requires at sea
(b) Suggest a method of repair when the rubbing surfaces Of the Oil seal get estate the defects that you would look for when the shaft is withdrawn in the dry-dock.
### Arrangement of an Oil-Filled Stern Tube
An oil-lubricated stern tube arrangement is designed to support the propeller shaft and provide a seal against the ingress of seawater and the egress of lubricating oil. The system consists of a cast iron or fabricated steel stern tube, which houses forward and aft white metal bearings. Lubrication and cooling are provided by oil, circulated from a gravity header tank that maintains a positive pressure differential over the external seawater pressure.
**Key Components:**
* **Stern Tube:** The main housing fixed to the stern frame.
