Class 2 (2nd Engineer) MEP 📅 Feb 2026
(a) Sketch and describe a high pressure cut-out in a refrigeration system. (6) (b) The refrigeration compressor has stopped due to operation of the h. p. cut-out. Explain – (i) The possible causes. (ii) How these causes would be found and possible remedies. (6) (c) What steps are taken if the compressor "short-cycle" on low pressure cut-out? (4)
### (a) High Pressure (HP) Cut-Out: Sketch and Description
**Purpose:**
The High Pressure (HP) cut-out is a critical safety device fitted to the compressor discharge line in a refrigeration system. Its primary function is to protect the system from over-pressurization. It stops the compressor motor automatically if the discharge pressure exceeds a pre-set safe limit, thereby preventing damage to the compressor, condenser, piping, and potential rupture of the system leading to a loss of refrigerant.
**Construction:**
