Q8
Sketch and describe a stockless anchor illustrating the method or device used to attach it to the chain cable. When the anchor and cable are ranged during the ships underwater survey what parts require special attention and what defects are likely to be discovered
(16)
### Description and Operation of a Stockless Anchor A stockless anchor is the most common type of anchor used on modern commercial vessels due to its ease of handling and stowage. It is designed to be housed directly in the hawsepipe, eliminating the need for the cumbersome deck stowage required by older stocked anchors. **Key Components:** * **Shank:** The long central bar of the anchor, which is connected to the anchor cable via the 'D' shackle at its upper end. The lower end is connected to the crown.
