Class 2 (2nd Engineer) MEKG 📅 Jun 2024
Sketch and describe a stockless anchor illustrating the method or device used to attach it to the chain cable. When are the anchor and cable ranged during the ships underwater survey what parts require special attention and what defects are likely to be discovered? (16)
### 1. Stockless Anchor: Sketch and Description
A stockless anchor is the most common type used on modern merchant vessels due to its ease of handling and stowage. It is designed to be housed completely within the hawsepipe.
**A. Principal Parts & Operation:**
* **Shank:** The long central bar that connects the anchor to the chain cable via a shackle at its upper end. It houses the pivot for the crown assembly at its lower end.
