Class 2 (2nd Engineer) MEKM 📅 Mar 2026
Q4 Sketch and describe the arrangement of a main engine camshaft chain. Describe the repair procedure following fracture of one chain link during operation of the engine, give possible reasons for the failure and explain how the chain is set initially at the correct degree of tension. (16)
### 1. Arrangement of a Main Engine Camshaft Chain
The camshaft chain drive is a critical system in a large two-stroke marine diesel engine, responsible for transmitting the rotational drive from the crankshaft to the camshaft at a precise 1:1 speed ratio. This ensures the correct timing of fuel injection and exhaust valve actuation.
**Components and Layout:**
* **Drive Sprocket:** A toothed wheel keyed onto the main engine crankshaft. This is the primary driving element.
