Class 2 (2nd Engineer) MEP 📅 Jul 2022
(a) Suggest four reasons why the temperature of the oil in the steering gear system may become excessive.
(b) With reference to steering gears explain how the ship may be steered in each of the following circumstances
(i) Destruction by fire of the primary supply cable
(ii) Destruction by fire of the telemotor lines
(iii) Bearing failure in the running pump
(a) Four reasons why the temperature of the oil in the steering gear may become excessive are:
Not enough oil in the system
Air in the system
High load on the system due to heavy weather
