ETO ETO Exam papers 📅 Sep 2024
(a) The capacitor-start induction motor has a much higher starting torque than the resistance split phase motor. Explain.
(b) A 100 KVA, 2400/240 V, 50 H, 1-phase transformer has no-load current of 0.64 A and a core loss of 700 W, when its high voltage side is energised at rated voltage and frequency. Calculate the two components of no-load current. If this transformer supplies a load current of 40 amp at 0.8 lagging power factor at its low voltage side, determine the primary current and its power factor. Ignore leakage impedance drop.
Given,
$$100KVA, \space 2400/ 240V,\space 50Hz,\space 1 - \phi$$
To calculate no load components:
Primary input current $$I_o = 0.64 A$$
