Class 1 (Chief Engineer) Engineering Management 📅 Oct 2022
The ESP (Enhanced Survey Programme) is applicable to bulk carriers and tankers.
(a) Explain the special risks of these two types of ships that have prompted the ESP.
(b) Citing casualty statistics, explain how the ship's age relates to these risks.
(c) State the major requirements of inspections under this program.
(d) What is contained in the ESP document or file?
### (a) Special Risks of Bulk Carriers and Tankers Prompting the ESP
The Enhanced Survey Programme (ESP) was specifically developed to address the unique and severe risks associated with bulk carriers and oil tankers, which were not adequately covered by standard survey regimes.
* **Bulk Carriers:** The primary risk is catastrophic structural failure, which can lead to rapid sinking. This often occurs with little to no warning, resulting in the total loss of the vessel, its cargo, and tragically, the crew. These failures are typically concentrated in the main cargo hold structures due to stresses from heavy, high-density cargoes (like iron ore), corrosion, and physical damage from loading/unloading operations.
* **Oil Tankers:** The principal risk is structural failure leading to a breach of cargo containment. This results in massive oil spills and catastrophic environmental pollution. The consequences include severe damage to marine ecosystems, coastal economies, and protected sanctuaries. The financial and reputational losses from such an incident are immense. For tankers, critical areas include cargo tanks, ballast tanks, and pump rooms where corrosion and fatigue are prevalent.
