Class 1 (Chief Engineer) Engineering Management 📅 Apr 2022
The IMO has made several codes mandatory. Explain,
(a) What are the advantages of making codes in addition to conventions and purpose of making them mandatory
(b) Write the main contents of the "Intact Stability Code 2008"
(c) What is the importance of "FSS Code" and "FTP Code" in respect of fire related regulations?
### (a) Advantages of Codes and Purpose of Making Them Mandatory
**Advantages of using Codes in addition to Conventions:**
1. **Technical Specificity and Detail:** Conventions like SOLAS set out broad principles and functional requirements. Codes provide the detailed, prescriptive technical specifications needed to meet these requirements. For instance, SOLAS mandates a fixed fire-extinguishing system for the engine room, while the FSS Code specifies the exact design, installation, and testing criteria for such a system (e.g., CO2, water mist).
2. **Ease and Speed of Amendment:** Amending an international convention is a lengthy diplomatic process requiring ratification by a significant number of member states. Codes, however, can be updated more rapidly by IMO's technical committees (e.g., MSC, MEPC) through a 'tacit acceptance' procedure. This allows regulations to keep pace with technological advancements and respond quickly to safety incidents or new research.
