The LT cooler of the centralized cooling water system on your ship is showing poor performance. What measures you would initiate to rectify the problem and improve the performance.
(16)
### Introduction The poor performance of the Low Temperature (LT) cooler in a centralized cooling water system is a critical issue that can affect the operational efficiency and safety of numerous auxiliary machineries. The primary indication of poor performance is a reduced heat transfer rate, resulting in a higher than desired LT water temperature at the cooler outlet. A systematic and comprehensive approach is required to diagnose the root cause and implement corrective actions. The heat transfer process is governed by the formula: $$ Q = U \times A \times \Delta T_{lm} $$ where a reduction in performance is typically due to a decrease in the Overall Heat Transfer Coefficient (U), a reduction in effective heat transfer area (A) due to blockage, or a compromised Log Mean Temperature Difference (ΔT_lm) due to reduced flow rates. My response as a Senior Engineer would involve a three-stage approach: immediate on-watch actions, systematic investigation and rectification, and long-term preventive measures.
