Class 2 (2nd Engineer) MEP 📅 Aug 2022
(a) The UMS monitoring and control system of your ship has recently started to give false alarms and incorrect data printouts. State, with reasons, possible causes if the false alarms and readings are:
(i) Localised to a particular area of engine operation
(ii) General to the engine room
(b) State, with reasons, the action you, as Second Engineer, would take to ensure continued safe operation of the vessel if the defects were general to the engine room
(c) Explain the procedure you, as Second Engineer, would adopt in order to locate and rectify a general fault in the UMS system.
(a) Cause of False alarms and incorrect data printouts in the UMS system:
(i) Localised to a particular area of Engine room:
Damaged or degraded cables may cause short circuits or open circuits, leading to irregular signals and false alarms.
Faults in specific control cards or panels associated with a particular area can result in localized errors or alarms.
