Using sketches explain the difference between pulse and Constant Pressure turbocharger systems.
(a) In the event of one of the Pulse turbocharger's becoming inoperative due to mechanical breakdown explain the modifications required to allow the engine to operate safely.
(b) State the instruction you as second Engineer would issue regarding the additional engine monitoring requirements following the steps taken in (a).
