Class 2 (2nd Engineer) MEKG 📅 Oct 2024
What are the major types of stainless steels used on merchant ships? Briefly explain each type. Which grades would you recommended for use in sea water environment? Why? (16)
### Introduction to Stainless Steels in Marine Applications
Stainless steel is a family of iron-based alloys containing a minimum of approximately 10.5% chromium. This chromium content forms a passive, self-repairing layer of chromium oxide on the surface, which provides its characteristic 'stainless' or corrosion-resistant properties. In the demanding marine environment, characterized by high humidity, salinity, and chloride concentration, the selection of the correct grade of stainless steel is critical to prevent premature failure of components and ensure the structural integrity and safety of the vessel.
### Major Types of Stainless Steels Used on Merchant Ships
There are four principal families of stainless steels used in marine applications, each distinguished by its crystalline microstructure:
